Dvr - AVS Forum | Home Theater Discussions And Reviews
Old 10-01-2005, 09:12 PM - Thread Starter
boffo13's Avatar
Here is my issue. I have a Scientific Atlanta HD DVR through Time Warner Cable. I went into settings on my cable box and set the resolution to 720P, well my TV doesnt support 720P. SO after a series of flickers I now have nothing but a blue screen on my 55" HD Mitsubishi TV. My TV only supports 480I, and 1080I. I cannot access the cable box via the remote to put the settings back to 1080I. Time Warner is sending out a Tech tomorrow. My first question is how can I change the settings on the cable box without using the remote? Any help on how I get my picture back?
boffo13 is offline
Old 10-01-2005, 11:13 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Nevermind - i responded to your other post in the HD Recorders Forum since it doesn't really belong in this one anyway.
http://www.avsforum.com/avs-vb/showt...95#post6286895
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
