SA 8000HD - Semi-Official Chat - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-18-2005, 12:31 PM - Thread Starter
iontyre's Avatar
Just got one of these through Comcast, and so far I LOVE it!!! Don't even have my HDTV yet (won it, its on the way) but get great picture at 480i from HD stations on my Toshiba 32" SD TV. DVR was tested this morning, and appears to work fine. Any other experiences?
Proud Galactic Imperialist
iontyre is offline
post #2 of 3 Old 10-18-2005, 01:08 PM
Chocolatemilk's Avatar
For a DVR it is ok. I think it is rather slow tracking from SDTV to HDTV. Also the HD audio will take a really long time to come one sometimes when changing channels. Definately it is not friendly to channel surfers (my wife). This DVR is much slower than the directv or dish network models, maybe its just the processor and the 8300HD is better, but I have not upgraded to that model yet.
Overall the features that I wish it had was side by side PIP. So on a 16x9 set it can do channel X on the left and channel Y on the right, stretching it to full screen. Otherwise its a pretty good receiver.
Chocolatemilk is offline
post #3 of 3 Old 10-21-2005, 08:42 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 514 Post(s)
Liked: 772
I didn't think anyone was still giving out the old SA8000HD. It's pretty much been replaced by the newer/better 8300HD. If you can switch to one of these you'll be better off.
Which software does Comcast use for their DVRs?
I presume you're currently using S-Video or Composite, but once you get an HD TV you'll have to put the DVR into "HD mode" which will disable these connections and you'll be forced to use only Component for everything. SD looks terrible over Component on my 8000HD, but when i put it in SD mode and connect S-Video the SD picture is excellent. Unfortunately you cannot connect both outputs simultaneously on the 8000HD, but with the 8300HD all the outputs are active so you can connect both outputs and optimize the settings for each separately.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Closed Thread Digital Recorders (PVRs) General
