dct6412 III - comcast - no DVI - AVS Forum
post #1 of 5 Old 10-19-2005, 11:07 AM - Thread Starter
bwillis's Avatar
I had problems with my old 5100 (with DVI), so I took the box back to comcast and they gave me a dct6412 III.
I took it home, then as I was grabbing the DVI cable I had hooked up to my Sony TV I realized that the DVI port is missing!!!
Are there any other models that Comcast generally has that has the DVI, and doesn't have other problems?
I notice that it does have a HDMI port - is there such thing as an HDMI to DVI converter?
Any info appreciated - thanks!
bwillis is offline
post #2 of 5 Old 10-19-2005, 10:15 PM
Ronin_R6's Avatar
Originally Posted by bwillis
I
Yes, they are fairly common. You have a phase 3 box which is the newest. You may be able to ask your cable co for a phase 2 box like i have that has a DVI output and not HDMI.
Ronin_R6 is offline
post #3 of 5 Old 10-20-2005, 09:49 AM
cgriffith4's Avatar
I had the same problem with Comcast and the DVI connection. The new 6412 has a HDMI connection. Monster makes a HDMI to DVI cable which I am currently using and works great!! If HDMI is the same as DVI but it also transmits digital audio if you use as HDMI to HDMI cable. If you don't want to spend $99 on and HDMI to DVI cable then Comcast will give you a cheap HDMI to DVI cable for free. Good Luck
cgriffith4 is offline
post #4 of 5 Old 10-26-2005, 07:39 AM
neil0311's Avatar
There are many places to get a decent HDMI to DVI cable for a heck of lot less than $99. I got a 1 meter version at Cables for Less for $12.99. With a 1 meter cable and a digital signal, there is no physics that will back up the need for anything more. Digital is 0's and 1's, and the only thing that will cause a problem with the signal is if those 0's and 1's don't all get to the destination. The only way that's going to happen is if the length of the cable begins to be a factor. With anything up to 3 meters it's unlikely that length will be a problem.
neil0311 is offline
post #5 of 5 Old 10-26-2005, 07:59 AM
Bud-man's Avatar
monoprice.com.....'nuff said!
Bud-man is offline
Closed Thread Digital Recorders (PVRs) General
User Tag List
