Any way to skip ahead in large increments 6412? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2005, 11:00 PM - Thread Starter
mawst95's Avatar
Is there a way skip ahead in say 5 or 10 minute chunks with the Moto DCT-6412? Thanks!
Matt
mawst95 is offline
post #2 of 5 Old 10-31-2005, 08:02 AM
Bud-man's Avatar
No, you can adjust FF speed 3 times either way just keep hitting the FF or RR button 3 times you'll see more arrows according to what speed you set it too.
Bud-man is offline
post #3 of 5 Old 11-01-2005, 12:32 PM
Ronin_R6's Avatar
set up the 30 second skip feature on the comcast remote. then make a macro of how many 30 sec skips you want to execute, ie for 5 min skip use 10.
Ronin_R6 is offline
post #4 of 5 Old 11-02-2005, 06:37 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 511 Post(s)
Liked: 771
If the 6412 is running TWC/Passport software (like in OC) then it might have the ability to jump to 15 minute marks like the SA8000/8300 does.
Try this - hit FF then while the show is FF'ing press the Right Arrow key and see if it jumps to the 15 minute mark. This is how it works on the SA8000/8300 DVRs but i don't know if it works the same on Passport Motorola boxes.
If it's not Passport, then i doubt this will work.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 5 Old 11-03-2005, 04:23 PM
Bud-man's Avatar
Thanks Randy it worked on my 6412!!!!! 15 min jumps, you da' man!!
Bud-man is offline
Closed Thread Digital Recorders (PVRs) General
