Not enough outputs - AVS Forum | Home Theater Discussions And Reviews
Old 11-07-2005, 03:59 PM - Thread Starter
milliemagoo's Avatar
My cable DVR has one input coax (no output) & one audio output (which goes directly to the TV). There are several video outputs & one serial cable output.
I have a Hitachi tv when I use the serial cable the picture is a green/gray color. I went back to composite cables for both video & audio, works fine.
When I tried to hookup my Sony RDR-GX7 DVD Recorder there is no way to the audio output from the DVR.
The higher channels have to come through the box. Is there a way to split the signals coming out of the box to connect the audio to the DVD Recorder & the TV.
Thanks in advance.
milliemagoo is offline
Old 11-07-2005, 04:21 PM
TonyBDA's Avatar
Why don't you list the video outputs?
I'm curious, how are you getting video from a serial port?
TonyBDA is offline
