motorola dct6412 III front jacks - AVS Forum | Home Theater Discussions And Reviews
Old 11-10-2005, 09:59 AM - Thread Starter
DEVERSEN's Avatar
I cann't seem to find a way to record on the dvr through the front jacks? :confused: Also when i puse live tv or recordings the sound goes out and I have to shut off and than turn back on the drv to get it back? :eek: any Idas? motorola dct6412 III :confused:
DEVERSEN is offline
Old 11-10-2005, 11:24 AM
marstar's Avatar
The current on-line "manual" for the Motorola DCT 6412 indicates that the front panel A/V input ports are NOT CURRENTLY ACTIVE OR SUPPORTED at this time.
marstar is offline
Old 11-10-2005, 04:04 PM - Thread Starter
DEVERSEN's Avatar
Ok thanks. Anyone know of a way to make them active? and how about the ethernet port and usb ports on the back can they be used?
DEVERSEN is offline
Old 11-26-2005, 12:53 AM
gregcaulder's Avatar
They can and will only be activated by your local provider.
The ethernet port will only be activated when they need to use the cable modem that is built into the box. Yeas that is right all of the 6412 cable box's have a cable modem. And to use it you will need to connect to the ethernet port. Comcast will only activate it when they wil need it. As for the USB and smart card reader, and anyhting else that is not activated.
Greg
gregcaulder is offline
Old 11-26-2005, 12:58 AM
Why do you call it DCT6412 III. Is tha a newer model or something? Mine only says DCT6412 and that is it.
Greg
Old 11-26-2005, 01:13 AM
Dont belive anyhting on the motorola website. They have to display that information for smart customers so the local cable companies wont get bothered with rediciolus questions that they cant answer.
To see what is activatedo n your box jsut turn the poer off, immideatley after that hit the OK/Select bution on your remote, then from there go to Interface Statius, and there you will see what all is activated. By FCC law you have the right to a HD cable box that has active 1394 ports.
Greg
Old 11-28-2005, 03:14 PM
yogaman's Avatar
I believe there's discussion that newer models have HDMI ports, not DVI-D ports.
Thanks for the diagnostics menu information (PowerOff, Select/OK).
I see that my 1394 is INST, but ACTIVE PORTS = 0. That sounds right because nothing is connected, but should something say ACTIVE instead of just INST?
-yogaman
yogaman is offline
Old 11-29-2005, 02:32 PM
scanpa's Avatar
-yogaman
Only if you are using them.
On the newer DCT 3412 STB, all the front jacks, slots, ports are removed!
Comcast of Lebanon PA.
scanpa is offline
