moto 6412 help!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-27-2005, 01:56 PM - Thread Starter
seanm2's Avatar
Could someone please help a newbie record to DVD from my cox 6412 DVR??
Is there a simple way of doing this and is there a simple way of recording directly from the drive on the DVR to a PC?? I am not an expert. I just want to be able to access the data for my own use.
PLEASE HELP!!!! :confused: :confused:
Seanm2
seanm2 is offline
post #2 of 9 Old 11-28-2005, 01:33 PM
edklite's Avatar
grab your self an INVERTED TORX screw driver, open box copy the dvr hd to your hd. you won't be able to view it like that tho (well i think)
edklite is offline
post #3 of 9 Old 11-29-2005, 12:56 PM
Bud-man's Avatar
Say WHAT!!!, You cant just grab the hard drive and hook it into a winblows based machine, it wont recognize it, with linux you can, but there's easier ways like coping thru firewire to a HTPC of the easiest way is hook up a Dvd recorder thru s-vid and record your shows that way........that is the easiest less hassle way!
Bud-man is offline
post #4 of 9 Old 11-29-2005, 08:39 PM - Thread Starter
seanm2's Avatar
thanks guys but Od rsther not open up yje box.
Id like to;
1- record to the DVD recorder (answered)
2- download the movie files from the DVR HD to my PC
not sure why anyone would want to remove the HD from the box anyway?
seanm2
PS COX says the fire wire ports are disabled!! is that true? why the heck are they there and what the heck good is the USB port for???????
seanm2 is offline
post #5 of 9 Old 11-29-2005, 09:19 PM
edklite's Avatar
you can copy any hd to any other hd, and windows never even comes to play.
why copy to another drive? to save space on the dvr hd.
copying a dirve is much faster then recording or burnning thur an s-video, not to mention you are not getting no hd quality with s-video
without removing the hd from the box how else would you access its content?
as for the ports and etc. your cable company disabled them so you could not transfer the files you have saved on the dvr.
edklite is offline
post #6 of 9 Old 11-30-2005, 03:26 AM
Bud-man's Avatar
You can transfer thru FIREWIRE to a pc, lot's of info on that in this forum!!
HERE
Bud-man is offline
post #7 of 9 Old 11-30-2005, 08:50 AM - Thread Starter
seanm2's Avatar
Thanks Guys!
seanm2 is offline
post #8 of 9 Old 12-01-2005, 03:13 PM - Thread Starter
seanm2's Avatar
OK I got the video feed to record on my laptop, BUT
1- there is no sound, and 2- it plays back at double speed.
does anyone know what setting I can change to make the recording worth the effort??? (Im using capdvhs3066)
ps the instructions were great! I just need to tweak it !!!!!
sm
seanm2 is offline
post #9 of 9 Old 12-28-2005, 08:49 AM
IT-Geek's Avatar
do tell ;)
IT-Geek is offline
Closed Thread Digital Recorders (PVRs) General
