TIVO PC. IR Blaster, Motorola dct2224 questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-30-2005, 03:39 PM - Thread Starter
mojo0716's Avatar
I'm setting up a "TIVO PC" with Windows Media Center 2005 and an ATI Elite Wonder video card. I have a Motorola DCT2224 digital cable box and I would like to be able to TIVO and control the digital cable box from my PC via Media Center. From my limited research, I think I need an IR Blaster? Where do I get one that will work with my digital cable box and Windows MCE 2005?
thanks
mojo0716 is offline
post #2 of 2 Old 12-01-2005, 07:57 AM
11001011's Avatar
An Ir Blaster is really nothing more than an IrED (Infrared Emitting Diode, just like an LED but its Ir) on the end of a wire with a mini earphone plug at the other end.
I made my own IR blaster for my TIVO for less than $5 by using two IrED's and an earphone plug from Radio Shack. Since I was not sure what direction the IrED should be connected I used two and connected them in opposite directions.
I have also seen them on E-bay rather cheap too.
Unless your video card or computer has an output for the IR Blaster I am not sure how you will connect it to your computer.
You also might want to ask this question in the HTPC forum.
A 'phile and his money are soon parted...
11001011 is offline
Closed Thread Digital Recorders (PVRs) General
