Can a Satellite cable be used with a splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-08-2005, 03:17 PM - Thread Starter
Mark P's Avatar
Liked: 30
I am trying to hook up a DVR and need two sat ins obviously but I also want a normal sat receiver next to it and wanted to split 1 cable to run to both DVR and other receiver .
I tried sticking a splitter in line and get a searching for Sat. and tried 3 different splitters all with same results, am I missing something here?
Mark P is offline
post #2 of 3 Old 12-09-2005, 03:19 PM
MGardiner's Avatar
Mark,
It can't be done. U need a separate satellite connection for each. Even though your provider may say 2 tuner, it needs 2 sat connections.
MG
MGardiner is offline
post #3 of 3 Old 12-09-2005, 03:26 PM
kin@tvauthority's Avatar
Mark P,
WHat you want can definitely be done, but you will need a new LNB, or a switch built specifically for satellite that has two inputs and 3-4 outputs. Whoever installed your satellite should be able to help you out with that.
Quick edit. I should clarify...
It can be done, but you need special equipment and know how to do it.
kin@tvauthority is offline
Closed Thread Digital Recorders (PVRs) General
