Replacing HD in DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-15-2005, 03:00 PM - Thread Starter
helpless's Avatar
Has anyone replaced a Hard Drive in a DVR? I have a Samsung SIR-S4120R and the drive has died. Anyhelp would be great.
Thank you
helpless is offline
post #2 of 2 Old 12-18-2005, 09:58 PM
prospect60's Avatar
If you want a plug and play HDD, you can order from
http://www.weaknees.com/samsung_s4120r.php
If you wish to load your own then you should check out --
http://www.newreleasesvideo.com/hins...to/index9.html
You need a HDD, a bit of Linux ability, comfortable opening up your computer, and at least a copy of the original software on the Samsung. There are people around who share the loading software though it's a bit of a gray (well not so gray actually) are legally.
prospect60 is offline
Closed Thread Digital Recorders (PVRs) General
