Which is better: Moto 3412 or 6412? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-24-2006, 04:31 AM - Thread Starter
geodon005's Avatar
Quoted: 49 Post(s)
Liked: 82
Comcast is coming this Friday to install my digital cable (I am a long-time DirecTiVo guy and am crossing my fingers!) and I was wondering which is better, the 3412 or the 6412. My entire is ADS-ready and I was assured by Comxast that my address has ADS. Any preferences?
Thanks for your input. . .
geodon005 is offline
post #2 of 18 Old 01-31-2006, 08:18 PM
Mad-Phule's Avatar
New to this board...
I have spent most of the day reading the different post on subject of the 3412 and 6412 P III.
I contacted Comcast cable in the Philly area, and they informed me that both units are available and to stop by and pick up the one I want.
As far as I can tell the 3412 is digital tuner only (and according to Comcast that is supported in my area), and has a smaller size.
The 6412 P III is "newer" with its release last quarter of 2005.
I'm in a quandary, which is the best to pick-up.
As a side note: I plan on running the HDMI output to an HDMI input on the tv as well as digital coax to a Bose lifestyles 50.
Several of the comments have said you may not get the digital out on playback when using the HDMI. I thought maybe the 3412 or the 6412 P III might deal with this better.
Thanks for any feedback. :)
Mad-Phule is offline
post #3 of 18 Old 02-01-2006, 10:08 AM
little buddy's Avatar
The difference in the 3412 and the 6412 is as follows: The 3412 is a HD STB with only one tuner. The 6412 III is a STB with dual tuners and HDMI output. If you have the 6412 III with DVR and you record a HD program, you can also play it in HD. It just takes more of the DVR's hard disk memory to record programs in HD than it does in SD. The 6412 III DVR STB with HDMI output has a menu option called additional HDMI settings in which you have to make additional settings depending on whether your TV's digital input is DVI or HDMI. The previous versions 6412 I & II did not have those additional settings.
With the 6412 III, because it has dual tuners, you can record one program while you are watching another program. I have used the 6412 III HD DVR STB with HDMI output and have found that it works well. It has a firmware update that improves the SD PQ better than previous models.
little buddy is offline
post #4 of 18 Old 02-01-2006, 11:23 AM - Thread Starter
geodon005's Avatar
Quoted: 49 Post(s)
Liked: 82
little buddy:
what firmware version are you running on the 6412?
post #5 of 18 Old 02-01-2006, 12:29 PM
thedemon's Avatar
The 3412 has two tuners.
thedemon is offline
post #6 of 18 Old 02-01-2006, 01:40 PM
Originally Posted by geodon005
little buddy:
12.XXX FIRMWARE REVISION. THE OLDER MODELS USE 9XX.
THE MOTOROLA 3412 IS SIMILAR TO 6412 III, BUT HAS NO ANALOG TUNER AND CAN ONLY BE USED ON CABLE SYSTEMS WHERE ANALOG-DIGITAL SIMUCASTING (ADS) IS SET UP.
HOWEVER, I STAND CORRECTED. THE 3412 ALSO HAS 2 TUNERS.
post #7 of 18 Old 02-01-2006, 10:56 PM
Mad-Phule's Avatar
Thank you for the information.
I've seen these acronyms used here before. SD PQ. But I'm afraid I don't know what they are?
Comcast has informed me that our area has the ADS and so the 3412 will give us full functionality. Also the 3412 has HDMI output.
But , from what I see in the posts it looks like the 6412 P III might be the better chose.
Thank you
post #8 of 18 Old 02-02-2006, 04:27 AM - Thread Starter
geodon005's Avatar
Quoted: 49 Post(s)
Liked: 82
SD = standard definition
PQ = picture quality
post #9 of 18 Old 03-07-2006, 07:23 PM
SSUNBRN's Avatar
I currently have a 6412 III. My cable company tells me that the 3412 is a newer box. Is the 3412 better or should I just keep the one I have?
SSUNBRN is offline
post #10 of 18 Old 03-08-2006, 08:40 AM
fastep's Avatar
I had 3412 and when i switched from 1080i with hdmi to another format the picture was unwatchable. I called comcast and switched to 6412 III and problem was solved. I also noticed the 6412 III is faster.
Not sure if 3412 is worse or maybe i had a bad box but i'm VERY happy with 6412 series III firmware 12.18.
fastep is offline
post #11 of 18 Old 03-08-2006, 02:10 PM
SSUNBRN's Avatar
Thanks for your reply. How do you check the firmware?
Any other opinions?
SSUNBRN is offline
post #12 of 18 Old 03-22-2006, 10:27 PM
skipsterut's Avatar
To see your DCT 6412 III firmware version --
Press the Menu button
Be sure you are on the icon that looks like a house (the text says "Go to the Main menu") and select it
Scroll Down in the menu to to "Setup" and select it
Go to "Cable Box Setup" and select it
Go to "Configuration: Select to Display" and select it
This shows a two-column read only list of settings. The firmware version is in the second column near the bottom.
Other Opinions? -- Yes. I haven't used the 3412, so can't offer anything there -- BUT I just upgraded from the 6412 II to the 6412 III and I see a MAJOR difference in both anlaog and digital SD PQ (especially analog) :) . Obviously it's not HD quality, but very much improved and very watchable (IMO) -- especially compared to the highly pixelated, completely crappy :mad: SD PQ of the 6412 II. Everything else about the III seems to be as good or better than the II -- and so far I'm happy with the change -- especially for the SD PQ.
BTW -- not sure if it matters for SD PQ, but my firmware version is 12.18.
skipsterut is offline
post #13 of 18 Old 03-28-2006, 09:27 AM
jay19bm's Avatar
I also have this problem, but it isn't as bad as you think. I don't have an HDTV but I do have an HDTV ready dlp projector. So when I change between the HD channels and the SD channels on my 3412 the output signal changes from 1080i to 480i (or p?) and the transition is fine. It takes a second to readjust to the 480 signal. However, if I go from the SD channel to the HD channels I have to hit the auto-adjust button on the projector to change to the new input format (1080i). I'm not sure if this is a problem with the way the 3412 outputs the signals or if it is my projector not recognizing the change automatically.
Other than that I haven't really had many problems witht the 3412. Sometimes it's slow to react to pause or play, but that usually is fixed within a couple seconds. The only real complaint I have is that the shows get cutoff the last minute (probably due to the show lasting til 10:01 or something instead of 10:00), so I watch the entire show and sometimes (usually) miss the last minute.
anyways, just wanted to give some more info about that issue.
jay19bm is offline
post #14 of 18 Old 03-30-2006, 07:37 AM
VideoNavi's Avatar
Another thing to consider is the 3412 outputs it's on-screen graphics (menus etc.) to all video ports, even when set to HDTV resolutions 720 or 1080i. The 6412 will not output graphics to composite/s-video when set to HDTV resolutions. You might ask why this would matter, but if you have a Sling box or Sony location free TV product (LF-Pk1) then you need the graphics active on composite/s-video even when your set to HDTV resolutions.
Having both a 6412 II (DVI output) and 3412 in the house, I'd go for the 6412 the speed of the remote commands works much better. The 3412 pauses and takes longer to think about doing things like playback, rewind, ffwd, replay etc.
VideoNavi is offline
post #15 of 18 Old 03-30-2006, 12:25 PM
jasper vicenti's Avatar
If you press power and then select menu immediately afterward, you can change the video output of HD and SD content. For SD, try changing the 4:3 override option to 480p or turning it off. This may help with your situation but may affect picture quality one way or the other, depending on the relative quality of your projector's built-in scaler/deinterlacer.
jasper vicenti is offline
post #16 of 18 Old 03-30-2006, 12:48 PM
JoePerri's Avatar
[BTW -- not sure if it matters for SD PQ, but my firmware version is 12.18.
Does anybody know how to look up the firmware version on 6412 issued from COX with the passport OS? The steps are not the same.
Joe
JoePerri is offline
post #17 of 18 Old 03-30-2006, 08:51 PM
MB The Body's Avatar
I have a 6412 ... how do i know if I have a I, II, or III though ?
I have the common problem with the Dolby Digital not showing up during playback and I was in the other thread but I came over in this one and noticed you talking about an HDMI Menu... we don't have that.
I have tried switching from the HDMI to component cables for the video and continuing to use the digital optical to have dolby digital for my recordings but that did not solve the problem of recordings not getting the DD 5.1
I have firmware 12.18
any ideas?
MB The Body is offline
post #18 of 18 Old 03-31-2006, 10:32 PM
cwerdna's Avatar
geodon05: What area are you in? What software is available on the 2 boxes from your cable provider? The DCT-6412 cold be running MSTV, Pioneer Passport Echo or TV Guide. They are all totally different from each other.
Go to http://broadband.motorola.com/dvr/dc...ia_demo_lo.asp and click on Interactive Program Guide in the flash movie to see what I'm talking about.
cwerdna is offline
Closed Thread Digital Recorders (PVRs) General
