Woo Hoo! Just had Cox replace my DCT6412 with a DCT6416! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-07-2006, 07:26 PM - Thread Starter
GeneL's Avatar
Only problem was after the tech left the unit kept rebooting every ten minutes.
A Cox supervisor told me he had had the same thing happen yesterday with another customer. He said that it was downloading software and, in the case of his customer yesterday, that the rebooting had stopped after a while and then was ok.
It took quite a while for the annoying reboots to stop on my unit but everything does seem ok now. (written with fingers crossed)
I wasn't given the specs on this unit but the installer
thought that this unit has a bigger hard drive than the DCT 6412. This would be a welcome upgrade feature,
Now if it will only work reliably, a feature that none of my oft replaced previous Moto DCT boxes could claim.
Btw, I just found the specs on Moto's site: (the forum won't let me post as a clckable url until I have more than five posts, sorry :(
More woohoo! 160gb 40gb better than my previous box.
That's just my opinion, I could be wrong.
GeneL is offline
post #2 of 5 Old 02-23-2006, 05:05 PM
kronin448's Avatar
Do you know if any of the USB, FireWire, or SATA outputs are enabled on this new version box? I'm also in OC.
kronin448 is offline
post #3 of 5 Old 02-23-2006, 09:40 PM - Thread Starter
GeneL's Avatar
I'm not sure about this, but I was told that the FW output is active.
Btw, I did have one unexpected "reboot" the other night but that was it. No more so far.
The one other issue for me is sound related. I don't know if it is due to my receiver or the PVR because, every so often, the sound either cuts out completely, the front channel disappears or the sound only comes from the left front speaker???
If I turn my receiver off and on again it will sometimes clear the problem.
This isn't a problem if I only use the TV's built-in speakers.
GeneL is offline
post #4 of 5 Old 03-16-2006, 08:23 AM
destrekor's Avatar
i believe FCC requires all firewire ports to be active. the other ports typically are disabled unless a cable provider specifically asks and pays for the ports to be enabled.
destrekor is offline
post #5 of 5 Old 03-22-2006, 08:48 PM
shugazer9's Avatar
I just swapper out a 6412 for a 6416. The firewire is indeed active. I noticed a quirk that is present on both boxes. For some reason, Fox Soccer Channel always loses the ability to fast-forward. I have to reboot to be able to fast forward.
"Any sufficiently advanced technology is indistinguishable from magic"-Arthur C. Clarke
shugazer9 is offline
Closed Thread Digital Recorders (PVRs) General
