Originally Posted by
skipsterut /forum/post/0
As mentioned in previous posts in this thread (and also many other threads -- see the link in post #2 in this thread) this is a general problem. There is no current fix.
The Comcast lady was wrong about HDCP being disabled. If you connect the HDMI from the Moto box to the TV it should display just fine. IF HDCP weren't enabled you wouldn't see anything this way either. I have read the HDCP spec and I believe the problem is that the 6412's HDCP is only enabled for display devices and not for "repeater" devices such as a receiver.
Until Motorola fixes the problem there are only a few things you can do -- none of which is what you really want, but it's all you'll be able to do for now --
1. If you want to switch all video through your receiver you can still use the reciever's HDMI output to your HDTV, except that you will need to use the component output from the Moto 6412 box to your receiver and let the receiver upconvert it to HDMI. This is probably the best option in that all video is going through the receiver and you have just one connection between it and the TV. The only drawback is it doesn't give you pure digital from the cable box to the TV.
2. If you want pure digital from the cable box to the TV via the HDMI output of the Moto 6412 there is no way to plug it into the receiver and have it work. So you will have to plug it directly into your HDTV. If your TV has 2 HDMI inputs you can plug the receiver's HDMI into the other one and then use the TV to switch between the cable box and the receiver for its input source. i.e., use the TV's remote to switch between the TV's HDMI 1 and HDMI 2 inputs depending on whether you want to watch TV or some other video source that's going through the receiver.
3. If your TV only has one HDMI input, and you want to use it for the cable video, then you will need to use component input on the TV to connect the receiver and not use the receiver's HDMI at all. The you would switch the TV input between HDMI and its Component input. I think this is the least desirable option of the 3, but it's your choice.
Obviously since you won't be using the HDMI from the Moto to the receiver you won't be able to use it for audio, so you will also need to connect the optical digital audio from the Moto to the receiver -- unless of course you want to use your TV for audio !!
There may be other options to connect your system -- maybe someone else has a better idea. But since the Moto box's HDMI will not work with a receiver, it's a question of picking the least bad of the options -- given your preferences and other video signal processing needs/options.
BTW -- I am working with a Comcast engineer (via e-mail) who has a contact at Motorola. I'm trying to find out if they are even working on this problem, and if so, when they might have a solution. I'll post to this thread anything I find out.
