Motorola 6412 Records but won't Play! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-27-2006, 08:31 AM - Thread Starter
rmcalhany's Avatar
Anyone had a similar problem, or can suggest how to fix it?
It is recording my shows just fine. I can select a recorded show, get info and even delete it. However, when i try to play it, the unit reverts to what I was watching before I tried to play a recording.
Then, to make it worse, after I have tried to play a recorded show (unsuccessfully), when I try to change channels, every channel is a black screen. It is like it loses a connection w/ the cable feed when this happens.
I have to turn the unit off, then back on to be able to view channels again.
Thoughts? Can I reset this to factory specs w/o losing my recorded shows? If so, how do I do that? Other options?
Robert
rmcalhany is offline
post #2 of 5 Old 02-27-2006, 09:13 AM
DarthJedi's Avatar
Robert
Yes; I have had the same problem, I also have a problem with the sensitivity of the IR on my box. I just upgraded to the phase III from the phase II. The problem that you are having can be fix by unpluging the unit. This will cause the unit to reset itself and will fix the problem. It is a pain in the a!@ but will fix the problem.
Now someone help me :) . My phase III is having a hard time picking up my remote signals from indirect line of sight from about 12 feet away. I never had this problem with the phase II box. I have a Harmony 880 remote.
May HD be with you always
DarthJedi
XBOX LIVE: ForceFields
DarthJedi is offline
post #3 of 5 Old 02-27-2006, 12:22 PM - Thread Starter
rmcalhany's Avatar
thanks - but will I have to set up all my scheduled recordings again? go through the setup again? or just unplug and re-plug?
I'll give it a go tonight.
thx
Robert
post #4 of 5 Old 02-27-2006, 12:23 PM
DarthJedi's Avatar
no, All of your settings will remain
DarthJedi
post #5 of 5 Old 02-27-2006, 02:31 PM - Thread Starter
rmcalhany's Avatar
Thanks - good luck w/ your remote issue, wish I could help.
Robert
Closed Thread Digital Recorders (PVRs) General
