Moto 6412 Power Off/Standby Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-11-2006, 09:22 PM - Thread Starter
Moebius's Avatar
Quoted: 146 Post(s)
Liked: 88
I searched around, but couldn't find anything on this. I picked up a 6412 the other day so I can record some HD programming (keeping TiVo and waiting for Series 3, but needed a stop gap). The box tends to run pretty darn hot, so I've been turning it off at night. I'm assuming with the DVR that this would be more of a standby mode, but figured I'd ask.
Will the 6412 record scheduled items when the power is off? I noticed when I turn it back on, there's no buffer recorded, so I wasn't sure.
Remember, no matter where you go... You're not where you were anymore.
Moebius is offline
post #2 of 6 Old 04-11-2006, 10:18 PM
cwerdna's Avatar
It might differ depending on who's software is on it? Is yours running iGuide or Passport? (It's unlikely that it's MSTV.)
cwerdna is offline
post #3 of 6 Old 04-11-2006, 10:37 PM
cherry ghost's Avatar
Quoted: 18 Post(s)
Set something up to record, turn it off, and see what happens. Mine turns itself on and to the proper channel when it's time for a recording.
cherry ghost is offline
post #4 of 6 Old 04-12-2006, 06:35 AM - Thread Starter
Moebius's Avatar
Quoted: 146 Post(s)
Liked: 88
That was my next step, just figured I see if anyone knew before hand.
Moebius is offline
post #5 of 6 Old 04-12-2006, 10:05 AM
Andrew Wolfe's Avatar
From what I can tell - not only will the box record when turned off - but it won't even turn off the composite output signal. It just puts out a blank screen.
Andrew Wolfe is offline
post #6 of 6 Old 04-20-2006, 10:53 PM
NickDG's Avatar
There are some bugs with this. When it turns itself on to record, it will also turn itself off when it's done. This can be quit annoying if you start to watch tv in mid-record, even using the other tuner, the unit will suddenly turn off. For this reason I keep it on 24/7. This probably kills the life, but I am renting it anyways.
NickDG is offline
Closed Thread Digital Recorders (PVRs) General
