Recording to DVR from a Security Camera?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-20-2006, 07:35 AM - Thread Starter
DLP Man's Avatar
I've just purchased a mini-camera to use like a security/nanny camera in my home while I'm at work. I'd like to record to either my media center PC or my DVR. I can't seem to figure it out?? How would I set up the DVR timing to record the camera output going into the DVR's standard A/V jacks?
Can I have my normal coax cable connection running into my DVR that I record TV programs with, and also have the camera hooked up through a standard A/V(composite) jacks and record what the camera is doing??
I'm sure these are dumb questions, but unfortunately I don't know how to do this?? Any help would be appreciated!! Thanks!
DLP Man is offline
post #2 of 7 Old 08-20-2006, 05:00 PM
Joxer's Avatar
I'm not aware of any DVR that supports recording from external video jacks, only from the tuner. You can do it with a PC's video capture card though.
Joxer is offline
post #3 of 7 Old 08-21-2006, 01:40 PM
Rammitinski's Avatar
Why couldn't he record into a standalone, standard def DVR through a line input? Setting the timer on the DVR is relatively easy.
If you're talking about TiVo or a provider's DVR you can't - but why not a Panasonic or Pioneer or another brand?
Rammitinski is offline
post #4 of 7 Old 08-26-2006, 10:05 AM - Thread Starter
DLP Man's Avatar
I just was informed by Motorola that my DVR will not be able to record from the A/V jacks as I hoped.... software issue! Does anyone know if it's possible for my media center pc to record through it's a/v jacks?? Thanks!
DLP Man is offline
post #5 of 7 Old 08-31-2006, 10:55 PM
h00ligan's Avatar
we actually use a dvr recorder for security at work.. it has some ups and downs... it also has a burner built in to archive the bookmarked footage. Obviously you don't record continuously but by motion - the dvr would fill fast with fmv... unless you are worried about one source.
If you want the info i can get you the name, it's not a cheap solution but it works well (once properly configured0 on our 12 cam system.
h00ligan is offline
post #6 of 7 Old 10-01-2006, 11:37 PM
Diver's Avatar
Panasonic makes a DVD recorder, will record up to 8 hours on one DVD. Just connect the camera to one of the composite (yellow) inputs, set the recorder to record on the appropriate input channel, schedule the record start & stop times.
Diver is offline
post #7 of 7 Old 10-02-2006, 09:33 PM
FarmBubba's Avatar
I know some web-cam software will do the trick. Haven't used any of them though.
FarmBubba is offline
Closed Thread Digital Recorders (PVRs) General
