Buy or rent a DVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-30-2006, 01:38 PM - Thread Starter
bulls23337's Avatar
I was just wondering if you guys rent out your DVR built-in with your digital cable box or buy your own cable box with built-in DVR, or buy your own seperate DVR. What would you guys recommend? Thanks!
bulls23337 is offline
post #2 of 7 Old 08-30-2006, 02:02 PM
Nitemage's Avatar
Quoted: 50 Post(s)
Liked: 30
At $6 a month it is usually much cheaper to just rent a DVR from the cable company.
Most commercial DVR's like TIVO require you to buy the unit for several hundred dollars in addition to paying a monthly fee.
Nitemage is offline
post #3 of 7 Old 08-30-2006, 02:09 PM - Thread Starter
bulls23337's Avatar
i was just browsing some DVR players on ebay and you can buy a DVR for around $200 for a Motorola. you can even buy the same cable boxes with built-in DVRs that the cable companies use for around the same i think. :)
i didnt know Tivo was like that. glad i wasnt looking into those. thanks for the opinion!
post #4 of 7 Old 08-30-2006, 03:22 PM
Rammitinski's Avatar
I'm pretty sure that you cannot actually use any of those boxes with your cable. You have to use one of theirs.
If you can still find a Sony DHG-HDD500 or 250 DVR/tuner, you can buy one of those and use it. But if you have digital cable or are using a cableCARD, you have to be sure they're still passing along the analog host channel (usually a PBS channel), so that you can get the info for the built-in TV Guide on Screen feature and use it to record.
Rammitinski is offline
post #5 of 7 Old 08-31-2006, 12:00 AM
Joxer's Avatar
Yeah watch out for those EBAY cable DVRs, they are usually stolen and won't be authorized by the cable company. Only rented DVRs and cable boxes are authorized by most cable systems. Renting is a better deal anyway considering the hardware can be upgraded rather often and you can just swap for a newer improved model at no extra cost compared to buying what could quickly become an obsolete model.
Joxer is offline
post #6 of 7 Old 08-31-2006, 10:29 AM
Andrew Wolfe's Avatar
I have both.
There is no great answer. The Cable company DVRs have dual tuner - but no capacity. The Sony has 500GB - but a crappy UI and only 1 tuner.
Andrew Wolfe is offline
post #7 of 7 Old 08-31-2006, 10:38 AM - Thread Starter
bulls23337's Avatar
hmm, i figured those ebay boxes were stolen lol.
looks like i'll be renting. thanks again guys! :D
Closed Thread Digital Recorders (PVRs) General
