DCT 3416 firewire drivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-06-2006, 06:54 PM - Thread Starter
jmiele4's Avatar
Please help! I just got a Motorola DCT 3416 from GCI up here in Alaska but I can not find the drivers for it to work with the Firewire. I tried using the drivers for the 64xx to no avail. I am running Windows XP Pro. The devices drivers needed are for AV/C Tunner and AV/C Panel. Ive read almost every post on here and they all focus on the 64xx series. Thanks for the help.
jmiele4 is offline
post #2 of 10 Old 01-02-2007, 07:19 AM
Kitten's Avatar
Me too. Have you found them yet. No they don't work from the 6412. Comcast here in Atlanta is spoiling all my fun. Can't save what's on the DCT 3416 forever w/o my computer having the drivers so I can make HD DVD's for my personal collection. Boo Hoo!!!
If you or anyone comes up with them please let me know. Motorola told me there aren't any yet for a computer. Don't believe it. Said some cable operatiors may support the 1394 soon. Help
Kitten is offline
post #3 of 10 Old 01-10-2007, 05:45 PM
robertmchenry's Avatar
Check this out;
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR
Should get you started on the right track
robertmchenry is offline
post #4 of 10 Old 04-25-2007, 01:48 AM
ajwees41's Avatar
Quoted: 20 Post(s)
Originally Posted by robertmchenry View Post
Check this out;
Doesn't work for the 3412-3416.
ajwees41
ajwees41 is offline
post #5 of 10 Old 08-06-2007, 08:32 AM
CColtManM's Avatar
Any update?
CColtManM is offline
post #6 of 10 Old 09-04-2007, 11:42 AM
themike5000's Avatar
themike5000 is offline
post #7 of 10 Old 04-09-2008, 01:27 PM
housefrough2007's Avatar
I got drivers for my win xp I'll post the web address in a second
housefrough2007 is offline
post #8 of 10 Old 04-09-2008, 01:30 PM
post #9 of 10 Old 09-26-2012, 10:32 AM
SysopChris's Avatar
Please help. I've been at this for 6 hrs. I'm a systems analyst on the IBM iSeries AS/400 developing software in COBOL & RPG/LE so I'm not totally technically illerate. But this is kicking my butt! For the most part I am hoping the fact it is not working is that I can't find Windows 7 or 8 64-bit drivers for the Motorola DCT-3416 AV/C (Panel & Tuner). Apparently a driver is needed for each. I'm runnig dual boot for Win 7 and 8 both 64-bit. If any screen captures will help I'll gladely post them on my Windows Live Skydrive and attach a Belarc report. Formatting my system and re-installing WinXP is not an option (at this point).
AMD Athlon X2 Dual Core BE-2400 2.30 GHz with 5 GB RAM.
Thanks in advance,
Chris
sysopchris@live.com
SysopChris is offline
post #10 of 10 Old 09-26-2012, 02:50 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
You have to have a 32 bit version of windows. No 64 bit windows drivers are avaliable. Sorry.
Stop working on it until you have a 32 bit OS installed, either xp, or 7.
qz3fwd is offline
Reply Digital Recorders (PVRs) General
