How long should a DVR last? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-07-2006, 04:58 PM - Thread Starter
Tickwood's Avatar
I am now on my fourth DVR in 20months. All have been Scientific Atlanta units (two SA-8000 and two SA-8300 units. All were furnished by Cox. The first died within amonth, the second lasted 8 months, the third about the same. Is this usual behavior for these units?
Tickwood is offline
post #2 of 5 Old 09-08-2006, 02:22 AM
Joxer's Avatar
Not for me. My SA8300HD is still working perfectly for about a year and a half.
Joxer is offline
post #3 of 5 Old 09-12-2006, 08:45 PM
Andrew Wolfe's Avatar
Disk failures are common. I have had over 10 DVR's from various manufacturers and it is not unusual for them to fail in a year. Many of them just run very hot.
That's one of the nice things about renting :)
Andrew Wolfe is offline
post #4 of 5 Old 09-25-2006, 07:00 PM
FarmBubba's Avatar
It all depends on how hot the hard drive runs, if the box you have does not have a fan, you might consider adding an external one. (or if your renting and need a new one, a towel could help it's demise...)
FarmBubba is offline
post #5 of 5 Old 09-25-2006, 10:42 PM
dailthegate's Avatar
I had a couple of Motorola DVRs go bad. Then I found a page about them getting to hot. I took the glass door off my tv stand. It was building up a lot of heat. That keep it cooler and running longer.
dailthegate is offline
Closed Thread Digital Recorders (PVRs) General
