Problem with my Comcast Motorola DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-17-2006, 12:55 PM - Thread Starter
chibul's Avatar
Not sure if this is the right forum for this or not for this.
When I picked up my Comcast DVR, they told me it would hold 60 hours of standard programming or 15 hours of HD programming. I currently have 15 1/2 hours of standard programming stored on it, and it says I'm 48% full. I've found no settings at all for quality of recording. Does anyone know why this would be happening?
chibul is offline
post #2 of 6 Old 09-17-2006, 10:20 PM - Thread Starter
chibul's Avatar
Anyone?
chibul is offline
post #3 of 6 Old 09-18-2006, 07:28 PM - Thread Starter
chibul's Avatar
I thought this forum was supposed to be helpful?
chibul is offline
post #4 of 6 Old 09-21-2006, 10:31 PM
Valpojim621's Avatar
What make and model do you have?
Valpojim621 is offline
post #5 of 6 Old 09-25-2006, 05:51 AM
bicker1's Avatar
This forum can only be helpful if there is an answer to be had. For some things, there simply is no assistance available.
My experience is that the hard drive percent filled number increases less, for each additional hour recorded. That has led me to believe that there is a set amount of the hard drive which is needed for the overhead of the disk OS, but the software is "smart" enough to still show 0% when there are no recordings (probably because some customer whined about it showing 15% filled when there were no recordings).
There are no settings necessary or provided, so don't worry about that.
bicker1 is offline
post #6 of 6 Old 09-26-2006, 06:10 PM
skanhome's Avatar
Had a similar issue. I have a 6412, and had a mix of SD and HD recordings that totaled around 78%. I cleared everything out to get back to 0%. I then recorded 2 hours of SD, checked the DVR, and I was at 48% !!!
I did a HDD format overnight: http://en.wikibooks.org/wiki/How_to_...ola_DVR/Resets
Once it was done, I recorded an hour of SD, and checked the DVR. 8% full.
skanhome is offline
Closed Thread Digital Recorders (PVRs) General
