Scientific Atlanta Explorer 8000 DVR -> PC Transfer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-05-2006, 12:30 PM - Thread Starter
Serihon's Avatar
Hello everyone.
I have a Scientific Atlanta Explorer 8000 box with DVR that allows dual show recording. Have a few questions.
Is it possible to remove files from this box and transfer them to a pc or another hard drive that can be used in a pc?
If it is possible how is it done? How much space am I looking at these shows taking?
How expensive might this cost?
I contacted Scientific Atlanta and asked them about this and they told me to contact Archos. I contacted Archos and they have a portable entertainment system that does this but it costs $350 which is a little more than I can afford currently. The cable box doesnt have a fireware outlet, but it does have a usb port on the front of it. I would appreciate any information anyone can help me with. Thanks!
Serihon is offline
post #2 of 5 Old 10-09-2006, 11:21 AM - Thread Starter
Serihon's Avatar
Wow. So much help on this forum I just cant contain myself.
Serihon is offline
post #3 of 5 Old 10-13-2006, 11:56 AM
Speedskater's Avatar
Quoted: 20 Post(s)
See some of the threads on the "HDTV Recorders" forum:
Kevin
Speedskater is offline
post #4 of 5 Old 10-31-2006, 02:36 PM
Coster's Avatar
Did you ever find an answer to this? I have the same questions and searching through this site is like wading through a jungle. Can't seem to find what I'm looking for.
Coster is offline
post #5 of 5 Old 01-13-2007, 08:07 PM
stewartg's Avatar
FWIW, you will never, ever, never, ever make friends and influence people with this kind of attitude. If someone had an answer, they would have provided it. No need for such a sarcastic and bitter response.
You don't like this forum? Don't post here.
stewartg is offline
Reply Digital Recorders (PVRs) General
