Comcast DVR powers-off after recording - AVS Forum | Home Theater Discussions And Reviews
Old 10-06-2006, 09:08 PM - Thread Starter
Delhux's Avatar
My Comcast DVR (Motorola 6412 dual tuner) seems to always turn itself off after a recording has completed if I am watching a pre-recorded video at the time.
Does this happen to anyone else? Could the DVR be responding to "off" commands my harmony remote may or may not have sent to it while it was recording?
Delhux is offline
Old 10-06-2006, 10:01 PM
mterzich's Avatar
Iv'e had that happen to me several times so I think that is a normal bug in the software just like the mute issue.
mterzich is offline
Old 10-07-2006, 05:25 PM
g35rocker's Avatar
What is the mute issue?
g35rocker is offline
Old 10-07-2006, 07:57 PM
mterzich's Avatar
If I remember correctly, the mute issue is that if a program is being recorded and you power on the TV, the sound will be muted from the DVR. For people using the standard remote this can be a difficult problem to solve since the mute button will usually mute the TV instead of unmuting the DVR.
mterzich is offline
Old 10-07-2006, 11:53 PM
scanpa's Avatar
There is no OFF mode to the STB unless you unplug it from the power socket. It is more of a sleep or standby mode.
There is no need to turn the STB to standby (off) mode. The only thing it does is shut down the Audio & Video Outputs and the STB LED Display. The HDD will still buffer the 2 tuners, and the STB will still be updating the IPG data and talking to your cableco's headend.
When the box is in standby (off mode) , it will wake from standby (turn on) for timed recordings and auto mute the audio outputs. (incase you left your audio or tv vol. on.
When the timed recording is done, it will put the STB back in Standby mode. It does not check to see if you are watching a pre-recorded show or the other tuner.
Best way to avoid both of these issues is to always leave the STB on.
Comcast of Lebanon PA.
scanpa is offline
Old 10-08-2006, 09:33 AM - Thread Starter
Delhux's Avatar
Wow, great response! Do you know what the power consumption difference is between standby and on modes for this device?
Delhux is offline
Old 10-08-2006, 10:23 AM
scanpa's Avatar
not much. about 3-7w at the most.
scanpa is offline
Old 10-09-2006, 08:01 AM
pstahl's Avatar
if the DVR was off when the recording started it will shut itself off after the recording is complete. I leave mine on most of the time so I don't have this problem. I don't think I ever had it recording while I was watching something that was pre-recorded.
pstahl is offline
