dvr card web problems.HELP? - AVS Forum | Home Theater Discussions And Reviews
Old 10-24-2006, 05:52 PM - Thread Starter
bobby-in-mass's Avatar
I have a dvr 4900 card from(cameraimport )
16 ch 240 fps.works fine in server system.
from outside computer Internet it loads screen with controls and says loading at bottom of screen but thats all it does?
I have 5 static ip's with an actiontec router.
the card says port 80= web and ports 2200 to 2232 are camera ports ( 1 for each camera) I opened thoes ports in the router and still nothing?
you can set the ports to what ever you need. any help?
thanks
bob
bobby-in-mass is offline
