Moxi BMC9012 memory help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-06-2006, 05:10 PM - Thread Starter
kastnna's Avatar
I accessed the diagnostic function of my Motorola BMC9012 "moxi" box. The cable provider is Charter. Under the "main overview" I only have 6136kb of free memory and the total memory is 126868kb. I only have 2.5 hours of SDTV recorded.
Both the free and total memory seem rediculously low. Any thoughts??
kastnna is offline
post #2 of 7 Old 11-14-2006, 09:07 PM
fizzle's Avatar
You are confusing memory with storage capacity. The memory in use by the Moxi in not unlike the memory in your PC. It is being used by the operating system, services, applications, etc. Your recordings reside on the hard drive (storage).
fizzle is offline
post #3 of 7 Old 12-01-2006, 10:20 PM
carl35's Avatar
I'm with Charter as well. I have a MOXI HDDVR cable box. Where can I get some technical information, like a manual, for this unit. everyone else provides one with new equipment. The MOXI is a shadow. Thanks.
carl35 is offline
post #4 of 7 Old 12-07-2006, 10:31 AM
ahelbling's Avatar
Its a Via board from what I can gather.
Processor VIA C3 733 MHz
Memory SDRAM 128MB (256MB for BMC 9012)
Drives 80 GB HDD (BMC 9012)
LAN 10 / 100 Ethernet
I/O · 1 DOCSIS cable modem
· 2 HDTV tuners (with conditional access)
· 2 TV support (BMC 9012)
· 1 Built in DVD / CD-ROM Drive
· 2 USB 1.1 or 2.0 ports
Andrew
ahelbling is offline
post #5 of 7 Old 12-12-2006, 01:01 PM
jt1266's Avatar
The moxi users manual is "built" into the unit's menu. See the "about moxi" menu option for user instructions that were formerly given out on paper as manuals.
jt1266 is offline
post #6 of 7 Old 12-14-2006, 06:34 PM
PC487's Avatar
There a FAQ posted by a helpful user of these forums. Google "SPL Moxi FAQ"
PC487 is offline
post #7 of 7 Old 12-14-2006, 06:35 PM
PC487's Avatar
also the "BMC90XX Q&A Discussion Thread" here has much useful information. If you can get through the 240+ pages of it.
PC487 is offline
Closed Thread Digital Recorders (PVRs) General
