CyberHome DVR 1600 MU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-16-2006, 12:27 AM - Thread Starter
amul06's Avatar
Hello experts,
Req help with the following. I own a CyberHome DVR 1600MU with Firmware current version 413.
1. I need device code for this DVR , so that i can configure it with my universal remote.
2. I need Link to latest firmware update. Info on the additional features supported by the new update is appreciated.
3. I understand it is compatible with NTSC and PAL systems and hence can also play both type of DVDs. But are the DVDs it records also compatible on both NTSC and PAL?
4. If not compatible with PAL, how to make it compatible..I am ready to go the extra mile.
amul06 is offline
post #2 of 4 Old 12-16-2006, 01:07 AM - Thread Starter
amul06's Avatar
Req experts help on the following.
1. I own an Insignia 7" Portable DVD PlayerIS - PD040922. It needs a tap(sometimes vigorous shaking) to set the DVD spinning and play. Finally when it starts, it sometimes freezes inbetween. As i am out of warranty, I need suggestions in repairing it myself.
2. I own another Insignia unit,8" Portable DVD Player ,NS-8PDVDA. I need device codes for any of these two units, so that i can configure them to my universal remote.
3. Is there anyway to configure these units to make them compatible to PAL system?
amul06 is offline
post #3 of 4 Old 12-30-2006, 03:40 PM
suncoastgal's Avatar
amul06,
if you get the device code I would like it also. The buttons on the remote are too tiny for me to see any longer so I would like to use on my universal remote also. Thank you.
suncoastgal is offline
post #4 of 4 Old 12-31-2006, 09:01 AM
kneedragger's Avatar
Quoted: 18 Post(s)
I would start at this place for anything that has to do with remotes.
http://www.remotecentral.com/
kneedragger is offline
Closed Thread Digital Recorders (PVRs) General
