Comcast / DishNet / DirecTV DVR Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-09-2007, 12:49 PM - Thread Starter
swspain's Avatar
I have an "HD compatible" TV. I understand that to mean it doesn't have a built-in HD tuner.
Do the DVR from these companies have built-in tuners, or would I need some kind of dedicated tuner to get HD broadcasts?
swspain is offline
post #2 of 3 Old 01-09-2007, 10:25 PM
Rammitinski's Avatar
Originally Posted by swspain View Post
Do the DVR from these companies have built-in tuners?
Yes. They all have tuners which will receive their own HD programming. But only the satellite companies' tuners include an over-the-air tuner (in case you also want to use it to get your local OTA's with an antenna).
You can also purchase standalone tuners which can receive the local HD/SD digitals through cable (QAM tuner) or OTA (ATSC tuner).
Rammitinski is offline
post #3 of 3 Old 01-10-2007, 08:32 AM - Thread Starter
swspain's Avatar
That's what I was after. Thanks for the info.
swspain is offline
Reply Digital Recorders (PVRs) General
