Can DVRs be used for OTA broadcasts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-23-2007, 01:07 PM - Thread Starter
Kokopup's Avatar
Okay, this may be the dumbest newbie question ever but...
I have new HD plasma TV and will have an antenna for OTA stations (no cable or satellite). Can I use a DVR? Are there special models for this kind of application? Obviously, I know nothing about these and would appreciate assistance.
Kokopup is offline
post #2 of 7 Old 01-24-2007, 04:24 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
You can use a Tivo Series 3 HD DVR to record OTA broadcast, but you'll have to subscribe to the Tivo service to make it work.
A better option would be to build/buy an HTPC.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 7 Old 01-25-2007, 02:02 AM
Rammitinski's Avatar
If you have a Fry's Electronics around, they might still have some of the Sony DHG-HDD500's or 250's in stock. They are tuner/DVR's with a free, built-in guide. People using it with with digital cable sometimes have problems with it (more specifically, with cableCards), but for OTA or analog cable, they usually work great. There's a big thread on them over in the HDTV Hardware area of this forum.
There are no fees involved in using them.
Rammitinski is offline
post #4 of 7 Old 01-25-2007, 07:07 PM
josh684's Avatar
There is nothing other than the DHG-HDD500 that wil record HD? I am looking for the some thing...
josh684 is offline
post #5 of 7 Old 01-26-2007, 12:56 AM
Other than a PC, there's the LG 3410a, which are older and really hard to find.
How about these?:http://www.shopping.hp.com/entertain.../1/storefronts.
Or: http://www.crutchfield.com/S-7BHTyv4...p.asp?g=197850.
The only other standalone DVR's available only record in standard definition.
What was the problem with the Sony's? Too expensive? Can't find them? They can usually be found on ebay for less than retail.
post #6 of 7 Old 01-26-2007, 06:17 PM
josh684's Avatar
Can't find them was my only problem, I also would have liked something with a DVD/HDD
josh684 is offline
post #7 of 7 Old 01-27-2007, 09:54 AM
FarmBubba's Avatar
There is no recorder I know of that will record Hi-def and put it on a DVD.
FarmBubba is offline
Reply Digital Recorders (PVRs) General
