Motorola DCT-6416 III issues (Cox) - AVS Forum | Home Theater Discussions And Reviews
Old 02-06-2007, 02:15 AM - Thread Starter
taugust04's Avatar
I have a Motorola DCT-6416 series three box thats having issues with dropped/choppy video when playing back recordings, at both HD and SD quality. This box is less than a week old. Otherwise, the box works OK. Anyone have similar issues? Known fixes? I know I can bring the box back and swap it out, but I read some where else of a guy who went through 3 of these boxes that all had the same issue. TIA.
-Ted
taugust04 is offline
Old 02-07-2007, 05:28 AM
regnib's Avatar
I have had occasional problem due to marginal signal strength when viewieng some programs. If you record such programs I believe this problem will exist in the recording as well. I would be more concerned if the original signal was error free and the recording was choppy.
regnib is offline
Old 02-09-2007, 01:43 AM - Thread Starter
taugust04's Avatar
I'm beginning to think that one of the tuners is bad. I was playing around with it the other night, and I noticed that if I hit "swap", the program on the other tuner was skipping and studdering often. I then reversed what was playing on each tuner, and sure enough the other program was now skipping instead. I'm bringing it back to the Cox office tomorrow. Ugh.
Old 02-09-2007, 01:28 PM
inteller's Avatar
ding ding ding! we have a winner. the tuner is bad. I have returned 4 of these boxes for the same issue you report. When I get a new box it is fine. They last about 4-6 months.
inteller is offline
