RCN/Motorola 6416 III My Recordings not appearing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-21-2007, 12:00 AM - Thread Starter
Lemistral's Avatar
I've looked around and haven't found any information on this problem so far, so though I would give it a try here. When I press MyDVR (or my recordings, whatever the button is) it comes up with the blue screen, some garbled symbols where the info usually is, and then nothing else. If I try to scroll down and press enter, either the recordings reappear or I get sent to the main menu. If I select My Recordings from the main menu, my recordings magically appear. This has only cropped up this evening- things were fine this morning.
I tried pulling the plug after shutting the unit down and that seemed to work the first time, but now it's doing it again
I have RCN, although I understand in my area they were recently bought by Astound- although RCN branding still shows in the guide. Any thoughts? I have a lot of content on there that I need to watch before wiping the hard drive, so any non-destructive advice would be appreciated.
Lemistral is offline
post #2 of 5 Old 02-21-2007, 05:00 PM
pstahl's Avatar
Mine did that today and if I hit the mydvr button a second time the menu came up like usual. I'm working night work and when I got up I noticed my STB got reset and the TV Guide was reloading. There must have been a glitch in the system. The mydvr button does what it should now.
pstahl is offline
post #3 of 5 Old 02-21-2007, 06:14 PM
srj45's Avatar
Both of my DVR's are doing the same thing. The My DVD button only shows weird symbols and no recordings. If I press Menu and then DVR the information and recordings are there. It also deleted my series recording for American Idol.
srj45 is offline
post #4 of 5 Old 02-21-2007, 06:16 PM
srj45's Avatar
Did you reset the box or did it automatically reset?
srj45 is offline
post #5 of 5 Old 02-21-2007, 09:50 PM
pstahl's Avatar
It did it while I was sleeping this morning. They must have realized the last update they sent was messed up and reset our recorders.
pstahl is offline
Reply Digital Recorders (PVRs) General
