Help with odd problem, Time Warner HD DVR aspect ratio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-21-2007, 04:48 PM - Thread Starter
NoPIX's Avatar
This is weird to me. I have a 4:3 panasonic television that is HD compatible. Everything is properly set with my tv and my box. But when I watch HD channels the black bars on the top and bottom of the screen are too big. The standard ratio is 1.78:1, but my bars more closely resemble 2:1. I've talked to customer service and even had a technician out here and he was clueless. I recently got a new box. With this one i was able to set the feed at 480p instead of 1080i and miraculously the widescreen bars are perfect. For now, this still looks good, so i'm doing ok. But does anyone know what the problem is? Any familiar experiences? I'm really confused as to why they would broadcast it with extra cropping.
NoPIX is offline
post #2 of 2 Old 04-21-2011, 09:50 PM
ruchika's Avatar
I was experiencing the same problem and I tried changing the settings. It worked for me. You can try this solution too:
1) Press the "Settings" button
2) Press the right arrow to go to "Display"
3) Press the down arrow to go to "Picture Size" which has 3 options "Normal" , "Stretch" and "Zoom". The usual settings are on "Normal" but you can change it to either "Stretch" or "Zoom"
4) Press the "A" button on the remote to save the settings and then "exit"
This should hopefully resolve the issue and not change it back to the previous one.
ruchika is offline
Reply Digital Recorders (PVRs) General
