cablevision 4250 box wont record to vcr-Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-09-2007, 08:55 AM - Thread Starter
dts hd's Avatar
My panasonic analog vcr will not record from the digital cable box ,
i get an HDCP error.
If i unplug the hdmi will it record then via coax which was connected also .
I thought it was the audio setting, i changed that but still got the error.
or is it limited to channels 2 to 99 , i was trying to record fsc 142.
If the WAF would spring for the extra $10 for the dvr box , i would not be posting .
I also have a Panasonic replay 1000, if i connected the ir blaster to it ,
would i still have the same problem. Thanks Nick
An older man once told me "as in life its the box that always gives you trouble".
dts hd is offline
Reply Digital Recorders (PVRs) General
