putting .ts files to dvd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-01-2007, 06:00 PM - Thread Starter
mattm58's Avatar
I have some non-HD cartoons I've saved from my motorola dvr to my pc. The .ts files are roughly 300mb for a 20 minute cartoon. I want to burn these to dvd so my kids can watch them in the car on an upcoming road-trip.
The problem I'm having is that when I convert these .ts files to mpeg2, they are coming out at over a gig each, so I can only fit maybe 3-4 20 minute shows on a dvd. How can I get more on there?
-M
mattm58 is offline
post #2 of 6 Old 05-01-2007, 06:08 PM
Jim J's Avatar
20 minute mpeg2 shouldn't be a heck of a lot more than 600megs (or at least can be with pretty good quality for the kids). What sort of bit-rates are you using? isn't the .ts mpeg2?
and how did you take the recordings off the moto?
Jim J is offline
post #3 of 6 Old 05-01-2007, 06:17 PM - Thread Starter
mattm58's Avatar
I'm taking the recordings off the moto over firewire with the firestb drivers and capdvhs.
I couldn't tell you the bitrates right off, I'm at work right now. I was converting them using hdtv2mpeg2 to convert the transport streams to program stream with all the default settings.
mattm58 is offline
post #4 of 6 Old 05-02-2007, 10:53 AM - Thread Starter
mattm58's Avatar
The bitrates are about 1600
mattm58 is offline
post #5 of 6 Old 05-02-2007, 04:28 PM
Jim J's Avatar
1600? shouldn't be so big. maybe the audio is getting converted to PCM by accident?
Jim J is offline
post #6 of 6 Old 05-07-2007, 08:21 PM
FarmBubba's Avatar
The audio would do it. I have run into that problem before.
FarmBubba is offline
Reply Digital Recorders (PVRs) General
