dvr to computer hard drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-15-2007, 10:56 PM - Thread Starter
mech1983's Avatar
I would like to record live tv and shows that I've recorded on my scientific atlanta explorer 8300hd dvr to my computer hard drive. Would this work if the cable goes into the dvr first, then into my computer via a pci capture device (such as the ATI TV Wonder 650 High Definition PVR & TV Tuner PCI Card), rather than connecting the cable directly to the pci capture device? Would I have to worry about any encryption or anything like that?
Thanks in advance!
mech1983 is offline
post #2 of 3 Old 06-21-2007, 12:07 AM
doc_chiron's Avatar
If your SA8300 STB has an IEEE1394 (aka FireWire) connector on the rear AND it is NOT disabled by the cable co (FCC rules say it cannot be disabled as some HDTVs use that instead of DVI or HDMI for input) then you need to read the following thread on recording HD from IEEE1394 to Windows XP.
There is a similar thread for MAC users.
http://www.avsforum.com/avs-vb/showt...hreadid=403695
doc_chiron is offline
post #3 of 3 Old 06-21-2007, 12:22 AM
doc_chiron's Avatar
Stop!!! Don't buy that tuner card if you just want to record the IEEE1394 output of the SA8300!
All you need is a FIREWIRE card. I just bought one on eBaaaaaaaaaay for $10, but I haven't tried it yet. I bought it for the same reason, to record the FIREWIRE output of my Motorola DCT6416 Dual HD tuner DVR.
Only downsides are that the connection is in real-time only (ie a 2 hr movie takes 2hrs to copy) AND you cannot set the DCT to sequentially play a list of recorded movies.
There may be other options listed in other threads.
Reply Digital Recorders (PVRs) General
