Is there a VCR replacement like PVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-02-2007, 05:42 AM - Thread Starter
linetest's Avatar
I want to buy some type of DVR to carry around while vacationing and camping. I may need to use it with Satellite or cable. Is there such a beast? With a simple VCR like connection between whatever may be converting the signal for the TV and the TV itself? I can't seem to find one that's not either proprietary (DirecTV) or has a fixed fee per month (I may use this machine only 2-3 weeks per year). Maybe I should just buy a new VCR if I can find one? Thanks.
linetest is offline
post #2 of 10 Old 08-04-2007, 01:46 AM
bfdtv's Avatar
bfdtv is offline
post #3 of 10 Old 08-07-2007, 03:56 PM
ex-navy's Avatar
Check out the Neuros OSD at Neuros Audio website
It has composite in and out, records to CF, SD, USB, network etc in 640x480
MPEG4 resolution.
I own 4 of them
ex-navy is offline
post #4 of 10 Old 08-28-2007, 07:50 PM
cmaxwell's Avatar
MPEG4 resolution.
I own 4 of them
i read a little bit on it but can you answer some questions for me? first off i have a laptop with windows xp, h20 direct tv and sxrd 60 inch sony #1 what do i need to record from the sat box or can i. #2 is it easy to install.# 3 can i play back what i recorded on the tv or pc only. # can you record a whole football game etc. thx in advance
cmaxwell is offline
post #5 of 10 Old 09-08-2007, 01:09 PM
Yoyoms's Avatar
I was looking at this to and was wondering about the directv recording looking for something to record. have the directv h20 also
Yoyoms is offline
post #6 of 10 Old 09-17-2007, 09:32 PM
howdydooit's Avatar
You might look at Archos. Some of their products have S-Video and / or composite video in/out, some with wifi support, etc. http://www.archos.com/products/gen_5...global&lang=en
howdydooit is offline
post #7 of 10 Old 09-18-2007, 01:03 AM
cinemascope's Avatar
If you can find one, Pioneer had a very useful machine with a Tivo DVR and a DVD recorder in the same chassis.
Look for a used one in great shape from a private party or a repuatable B&M, preferably with the lifetime subscription on the Tivo.
Certified: Vantage InFusion, AMX A.C.E.
Lutron HomeWorks, Lutron RadioRa2 (Level 2)
cinemascope is offline
post #8 of 10 Old 09-18-2007, 05:12 PM
catzilla's Avatar
Is the Neuro OSD work like DVR, can be programmed, scheduled to record any channel that I want?
catzilla is offline
post #9 of 10 Old 12-12-2007, 04:06 PM
fja
fja's Avatar
The OSD will allow you to record from any standard video source with RCA or S-video output (DVD player, VCR, cable box, DVR, ...). It has an IR blaster to change channels on the video source for scheduled recordings. Since it does not have a Tuner or an EPG, it is not a DVR, but it is a good option if you want to record content in the MP4 format on an external HDD or a networked drive. (Disclaimer: I work for Neuros)
fja is offline
post #10 of 10 Old 12-12-2007, 06:02 PM
Rammitinski's Avatar
Toshiba also had a couple of those that also gave you free, basic TiVo service with them.
I think the Pio's might've had that, too. At least the more expensive Elite.
Humax made them, too, but I don't think they had the free service.
But if you're vacationing or camping you'd better have a phone line or internet connection handy to use one.
Rammitinski is offline
Reply Digital Recorders (PVRs) General
