Which cables should I use for video/audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-16-2007, 08:24 AM - Thread Starter
theperson's Avatar
Hey I just got a DVR this morning, an 8300 or something. Hopefully I'm posting in the right forum...anyway, the guy put a coaxial cable in for audio/video and kind of ran out the door so I couldn't ask questions. I put an optical cable in the DVR for the sound part since I know that's the best option but I don't know about video. Is composite video better than the coaxial cable for video? And if it is, i know s-video is even better, but I don't know if i want to take out the s-video cable from my xbox 360 and switch it for the DVR.
I just wondered this because the guy didn't even ask if I wanted a better video/audio connection or anything...
theperson is offline
post #2 of 6 Old 08-16-2007, 09:21 AM
bfdtv's Avatar
If you have a HDTV, use HDMI or component.
If you have a SDTV, the order of preference is generally component -> s-video -> composite -> coax. It may be necessary to change the output settings for component before you can use it, so I would start with s-video.
If your display has component, I would use that for the Xbox. If your display only has s-video and composite, then I would probably use s-video for the Xbox and composite for the DVR.
bfdtv is offline
post #3 of 6 Old 08-16-2007, 09:45 AM - Thread Starter
theperson's Avatar
Yea I have an SDTV so I guess I'll go with composite.
post #4 of 6 Old 08-28-2007, 02:06 PM
Adrian7724's Avatar
So, is there a noticable difference between Component and HDMI? Currently I'm using component... HDMI cables are kinda spendy so I don't want to drop 40 bucks if I'm not going to notice the difference.
Adrian7724 is offline
post #5 of 6 Old 08-28-2007, 02:35 PM
bfdtv's Avatar
It depends on your display.
Digital display technologies like SXRD, LCD, and DLP do tend to benefit from an all-digital (HDMI) connection. Older CRT projection displays generally do not benefit. Be aware that the settings to achieve the same picture with HDMI and component are different, so if you tweaked your settings for component, you'll have to re-tweak for HDMI.
Note you can get a high-quality HDMI cable from Monoprice.com for about $15. If you need a length of 3', then their $4 cable should work just as well. There is no need to spend more than $20 on a HDMI cable.
bfdtv is offline
post #6 of 6 Old 08-28-2007, 02:39 PM
Adrian7724's Avatar
I have the Aquos 46 inch banding extrodinare model. Thanks for the info on the cable!
Reply Digital Recorders (PVRs) General
