SA 8300HD 30 second skip? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-09-2007, 07:39 AM - Thread Starter
jkelber's Avatar
I've heard rumors that there might be a way to program a 30-second skip for the SA8300HD box. Anyone know if there is? Or if there definitively is not?
jkelber is offline
post #2 of 6 Old 09-10-2007, 02:15 PM
NYFOOTBALLGIANTS's Avatar
If I have had this for a year and find out right now I could have had 30 sec skip this whole time I might have a heart attack
NYFOOTBALLGIANTS is offline
post #3 of 6 Old 09-10-2007, 04:31 PM
Joxer's Avatar
None that I've ever found. It depends on the OS, but for Passport it has a 15minute back or forth skip feature, plus about three fast forward and fast reverse speeds.
Joxer is offline
post #4 of 6 Old 09-11-2007, 01:36 AM
bfdtv's Avatar
No.
At one time, SARA had 30s skip, but it was removed a few years ago.
bfdtv is offline
post #5 of 6 Old 01-04-2009, 09:20 PM
skbrown's Avatar
Originally Posted by bfdtv View Post
No.
Is there ANY way to reprogram the Comcast (red button) remote control used with the Scientific Atlanta 8300HDC cable box to enable the 30 second skip feature? If not, is the only solution then to purchase a Logitech or similar remote control?
Many thanks for all replies!
SKBrown
skbrown is offline
post #6 of 6 Old 01-05-2009, 07:59 AM
bfdtv's Avatar
As far as I know, it is no longer possible to enable 30s skip on any Comcast SA DVRs, regardless of your remote. That function was disabled a few years ago.
bfdtv is offline
Reply Digital Recorders (PVRs) General
