How to get surveillance camera on one of my cable channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-11-2007, 08:58 AM - Thread Starter
jackyliang's Avatar
How do I get my surveillance camera on one of my cable Receiver. I can use channel from 870 to 900, Example I would like to get my camera on channel 870, which channel modulator I should purchase for this set up?
jackyliang is offline
post #2 of 3 Old 11-09-2007, 05:15 PM
buellwinkle's Avatar
I think that would require and indepth knowledge of your cable box and the right electronic hacking equipment. Have you considered something less challanging like a channel combiner. Do a google on this and see what you come up with. Most allow you to combine your signal into analog VHF channel 3/4, some do UHF.
buellwinkle is offline
post #3 of 3 Old 12-01-2007, 06:04 PM
snowbear's Avatar
You can get inexpensive cable modulators up to channel 135. Above that will be difficult or not possible. hometech.com has a good selection and a bit of tutorial information. They have a storefront in Cupertino, CA if you're near there. SmartHome.com has a bunch too (and probably on-line users manual downloads). Their storefront is in San Diego?
Mike
snowbear is offline
Reply Digital Recorders (PVRs) General
