scientific atlanta pvr explorer 8300 hd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-15-2007, 04:48 PM - Thread Starter
schlumbeb's Avatar
Hi everyone, have used a pvr explorer 8300 for a while and suddenly the box seems to be on for the last couple of days even though the box is turned off---a humming noise has not stopped for two days-- it used to stop after 2 or 3 minutes the box has been shut off--- should I be concerned with that issue...
schlumbeb is offline
post #2 of 2 Old 11-22-2007, 12:17 AM
efernandez_98's Avatar
OMG
Get out of the house NOW!
jk. call up your cable company for a replacement, you might have a loose fan or hard drive.
efernandez_98 is offline
Reply Digital Recorders (PVRs) General
