Expanding explorer 8300hd with external hard drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-16-2007, 06:13 AM - Thread Starter
cck42's Avatar
I purchased a Seagate 320gb external hard drive and connected it to my explorer 8300HD DVR with a PNY esata cable following all the instructions. I expected it to ask me if I wanted to format the disk. I never get that response. All it says is that it isn't communicating properly and to check power and connections. Funny thing is it knows it is there because if I turn it off it tels me that is has been turned off and that i need a DVR reset again to enable. I have powered the DVR multiple times. The drive is working because I was able to connect it via USB to my PC and it found it OK and gave me a directory of what was on the drive. Any ideas??
cck42 is offline
post #2 of 4 Old 11-27-2007, 08:34 PM
scamp0000's Avatar
I am having the same issue. I have Suddenlink in West Virginia and wonder if SL has updated the eSATA software/firmware?
scamp0000 is offline
post #3 of 4 Old 12-11-2007, 12:18 PM
djarvis179's Avatar
I too have purchased a Seagate 500gb "esata" drive and also get same notification. In reading the many posts, I find that most are talking about the Maxtor drives. Could it be that they only work with Maxtor? If anyone gets info on this problem please pass it along. I did not say that I am not using a "HD" DVR, I am using a Scientific Atlanta Explorer 8300 in Akron, OH thru TWC. thanks
djarvis179 is offline
post #4 of 4 Old 12-29-2007, 01:23 AM
Hughmc's Avatar
Quoted: 13 Post(s)
Liked: 39
Same here but I have a Western Digital My book.
Hughmc is offline
Reply Digital Recorders (PVRs) General
