Added 2nd Tivo & noticed lines on SD broadcasts on all TV's in house? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-18-2007, 10:30 AM - Thread Starter
tripleM's Avatar
Recently Added a 2nd S2 Tivo & noticed lines on SD broadcasts on all my TV's in house? They look like faint diagonally scrolling white lines.
I know it is interference some where most likely the new additional TiVo?
I have a splitter on each of the Tivo 1 & 2 in the house.
I have Cox cable coming into the A/V distribution panel in the basement with a cable amp (Cox supplied) attached to it
Any insights would be appreciated.
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #2 of 4 Old 12-18-2007, 11:49 AM
bfdtv's Avatar
This is caused by a "ground loop" issue. Either your power outlet or coax is not properly grounded. Google "ground loop" for more information.
If you don't want to fix your wiring, you can solve the issue with a ground loop isolator like this. Some surge protectors also have these built-in.
bfdtv is offline
post #3 of 4 Old 12-18-2007, 12:20 PM - Thread Starter
tripleM's Avatar
Thanks. I will look into it. Questions:
It doesn't have to buzz to be a ground loop?
Do you install this @ the point of cable entry (distribution box) or near the component (Tivo) entry?
tripleM is offline
post #4 of 4 Old 12-18-2007, 12:44 PM
bfdtv's Avatar
Ground loops can cause buzzing, but typically do not.
They are typically installed before the component.
bfdtv is offline
Reply Digital Recorders (PVRs) General
