8300HDC Signal Souce Switching... HELP!!! - AVS Forum | Home Theater Discussions And Reviews
Old 12-19-2007, 09:53 AM - Thread Starter
fe342185's Avatar
My old 8300HD broke (No Audio) and Time warner replaced with 8300HDC. The problem I have is that I have a GEFEN 2x2 HDMI switch/Splitter. When the signal changes from 480 to 1080 and vice versa, the switcher takes 10 - 15 seconds to pur the video onto the screen. The old box kept the signal at a constant 1080i no matter if it is HD or not. About 1/3 of the time when I switch from HD to non HD source the audio or the video gets lost. Probably due to the security features built into HDMI.
Any work arounds?
Thank you in advance
RD
fe342185 is offline
Old 01-03-2008, 11:56 AM
awarsoca's Avatar
I think you got set it to upconvert all signals to 1080i. Its under the settings, more setttings button. It probably says HDMI right now and it needs to be upconvert 1 or upconvert3, i can not remember which is 720p and which is 1080i
awarsoca is offline
