Verizon DCT6412 Setup Problem, Advice Needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-21-2007, 07:16 PM - Thread Starter
mark46's Avatar
I had a Verizon technician over to install FIOS. He ran into a problem getting the HD-DVR to work on my 4-year old Samsung 61" DLP. Using Component cables, he could get the HD channels to work, but not the non-HD channels, the video wouldn't display at all. He had the same problem on two different units tested. He could only get the non-HD channels working by changing the setting on the set top box to 480. A non DVR set top box worked fine.
I previously had a Comcast HD-DVR hooked up to this TV with no problems. I do not have a HDMI connection, so component seems to be the only acceptable choice.
We tried every setting on both the TV and set top box for three hours with no luck. I can't seem to find this issue discussed anywhere.
If anyone knows what could cause this and better yet, if there is a solution to try, that would be great.
mark46 is offline
post #2 of 4 Old 12-22-2007, 06:13 AM
bfdtv's Avatar
Assuming you have the new menu, do Power off -> Select -> Menu. Change 4:3 override to either "off" or "480p."
The 4:3 override setting determines how SD channels are output. Many displays -- including your own -- will not accept 480i over HDMI. Changing 4:3 override to "off" will scale SD channels to whatever HD resolution you selected.
bfdtv is offline
post #3 of 4 Old 12-22-2007, 11:21 AM - Thread Starter
mark46's Avatar
thanks for the tip, I'll give it a try.
mark46 is offline
post #4 of 4 Old 12-23-2007, 10:22 PM - Thread Starter
mark46's Avatar
bfdtv, thanks so much for the direction. I followed your instructions and was able to get it to work. Disappointing that a Verizon technician couldn't figure that out and wasted hours of my time. Glad to have it solved, thank you!
mark46 is offline
Reply Digital Recorders (PVRs) General
