Tivo vs Directv HD DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-21-2007, 08:26 PM - Thread Starter
rikosuave's Avatar
Looking at getting a HD DVR tuner and noticed Directv wants a $5.00/mth DVR fee in conjunction with their DVR.
If I get a Tivo will they still charge me that monthly fee?
rikosuave is offline
post #2 of 7 Old 12-22-2007, 12:43 AM
Rammitinski's Avatar
Yes. And you can't use it with satellite.
Rammitinski is offline
post #3 of 7 Old 12-22-2007, 08:54 AM - Thread Starter
rikosuave's Avatar
Thanks Ramm.
post #4 of 7 Old 12-26-2007, 02:25 PM
Josh@dvdo's Avatar
Did you mean that you can't use it to receive terrestrial broadcasts (OTA)? It has to work on the satellite...
Josh Allen
DVDO Product Manager
Josh@DVDO.com
Josh@dvdo is offline
post #5 of 7 Old 12-26-2007, 03:31 PM
bfdtv's Avatar
He was referring to the TivoHD and Tivo Series3. Those don't support satellite.
They do support cable and OTA HD.
bfdtv is offline
post #6 of 7 Old 12-26-2007, 11:57 PM
11001011's Avatar
Tivo-HD and Series-3 only receive NTSC, ATSC, and QAM signals via their built in tuners they do not have an analog or digital video input, nor do they have any means of controlling an external tuner of any type.
So they will not work with a satellite receiver or a cable box.
If you want an HD DVR for Direct TV or Dish Network you will have to get it from them or build it yourself using a computer and capture cards.
Standard def Tivo's (series 1 and 2) will work with any type of external tuner as long as it has the right I/R codes to control the box via I/R blaster. I used my old series 1 with a high def cable box. The cable box output a down scaled composit video of teh HD progams. Sure it was not HD but it looked really good, much better than a standard channel's standard video output.
A 'phile and his money are soon parted...
11001011 is offline
post #7 of 7 Old 01-15-2008, 08:27 AM
Garman's Avatar
Quoted: 1184 Post(s)
Liked: 506
You can use a Tivo Hughes unit, but it will only do Mpeg 2 and you won't receive all the newer HD channels from DirecTV. If you buy it, they should only charge you for the service.... The Hughes unit does OTA, but the new HR21 are adding a device in Feb, that will allow you to use a OTA Ant.... Also hopefully Tivo and DTV have had more talks about adding them on the lineup again as far as a provider of boxes goes...
Dynaudio,Magnepan,Hegel, Musical Fidelity,Belles and KEF, etc...... Maybe New Belles Aria Int. Amp as far as equipment goes and for speakers the: Contour's 20's or Raidho next...
Charter Member - E.S.A.C. (Eastern Shore Audio Collective) http://www.esac.club/index.php
Kanso Audio Stand's http://kansoaudiofurniture.com/
Garman is offline
Reply Digital Recorders (PVRs) General
