Hack a Tivo Box/ serivce hacks??? etc? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-25-2007, 01:38 PM - Thread Starter
ambush276's Avatar
ok well i dont want to steal tivo service, but i have a tivo box that i got from a friend. I dont want to pay 10-15 a month for a DVR service, lol, but i was wondering if i took out the drive, and if there was an OS or somethign i could install that would work with the rest of the TIVO box. SO basically, i install the drive on my computer, then plug it back into the tivo, and wallah i have OS that uses the TIVO's input output's, w/ IR controller, my USB WIFI device, and downloads gudies! So basically not actually the tivo program, but a knockoff you could say. Or if you hack tivo and build like an Activation server off a linux distro??? anyways is this possible?
ambush276 is offline
post #2 of 4 Old 12-25-2007, 05:19 PM
bfdtv's Avatar
There is nothing you can do to the hard drive that will give you free DVR service of any kind.
bfdtv is offline
post #3 of 4 Old 12-26-2007, 01:55 PM - Thread Starter
ambush276's Avatar
so no linux distro or anything i can install that works with the tivo box???
any hacks of any kind ?
post #4 of 4 Old 12-26-2007, 02:30 PM
bfdtv's Avatar
There are plenty of hacks to enable / add features to the Tivo software (such as caller id on the screen), but none that give you free service.
bfdtv is offline
Reply Digital Recorders (PVRs) General
