DCH3416 backup to VCR or DVD-Recorder? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-11-2008, 09:16 AM - Thread Starter
cephraim's Avatar
I did some searching, but couldn't find the answer to this question.
Does the Comcast DCH3416 allow backing up of recorded shows to VCRs or DVD-recorders, or to PCs?
Eph
SA8300HD
TWC Rochester, NY
Navigator
Western Digital WD10EACS 1TB Hard Drive
Antec Veris MX-1 enclosure (Apricorn eSATA enclosure died)
LG 42LC2D 42" LCD
Harmony 670 remote
cephraim is offline
post #2 of 6 Old 01-22-2008, 12:19 PM - Thread Starter
cephraim's Avatar
Any thoughts?
Thanks again,
Eph
SA8300HD
TWC Rochester, NY
Navigator
LG 42LC2D 42" LCD
Harmony 670 remote
cephraim is offline
post #3 of 6 Old 01-24-2008, 07:37 PM
soulfly's Avatar
You should be able to if you have a dvd burner or vcr in line with the box. You would just have to watch and record at the same it.
soulfly is offline
post #4 of 6 Old 01-24-2008, 07:40 PM - Thread Starter
cephraim's Avatar
Thanks - but can you transfer the prerecorded shows to VCR or DVD, or can you only transfer things you are watching live?
Also, what outputs would you use on this box?
Thanks again!
SA8300HD
TWC Rochester, NY
Navigator
LG 42LC2D 42" LCD
Harmony 670 remote
cephraim is offline
post #5 of 6 Old 02-03-2008, 08:57 AM
soulfly's Avatar
pre recorded will work. The rf output on that box converts the output to analog, so you could do any program you record, I wouldn't do hd stuff though.
soulfly is offline
post #6 of 6 Old 02-03-2008, 09:28 AM - Thread Starter
cephraim's Avatar
SA8300HD
TWC Rochester, NY
Navigator
LG 42LC2D 42" LCD
Harmony 670 remote
cephraim is offline
Reply Digital Recorders (PVRs) General
