Motorola DCT 6412 III and two television setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-13-2008, 10:11 AM - Thread Starter
bskuared's Avatar
Hi all
I have the Cox Cable Motorola DCT 6412 III hooked up to my Onkyo 605 receiver via HDMI and then out via HDMI to a LCD in the living room. On the other side of the wall, in my office I have another television. I would like to connect this televisionto the DCT 6412 via component connections to use when I"m not watching TV on the lcd in the other room. Will this work? I can just pass the component cord through the wall... Also maybe I can hook up an RF to the DCT 6412 so I can us an RF remote to control the DVR in my office room? Thoughts.
bskuared is offline
post #2 of 7 Old 01-14-2008, 07:28 AM - Thread Starter
bskuared's Avatar
Hi all.. really looking for some feedback. Thanks.
bskuared is offline
post #3 of 7 Old 01-14-2008, 10:56 AM
bfdtv's Avatar
bfdtv is offline
post #4 of 7 Old 01-14-2008, 09:31 PM - Thread Starter
bskuared's Avatar
Thank you! Probably sounded like a simple question amongst all the complicated things you techie wonks are doing on this forum.......
bskuared is offline
post #5 of 7 Old 01-17-2008, 10:18 PM - Thread Starter
bskuared's Avatar
Well, it doesn't work because apparently the Motorola cable box exports 720p over the component connections. My tv kept saying "not compatible with the signal". I had to downgrade to composite.
bskuared is offline
post #6 of 7 Old 01-17-2008, 10:43 PM
bfdtv's Avatar
The Motorola outputs the same resolution over HDMI and component.
To change the output resolution, turn the box off and press menu.
bfdtv is offline
post #7 of 7 Old 01-17-2008, 11:37 PM - Thread Starter
bskuared's Avatar
Thanks... however it's also hooked up to my Samsung LCD via HDMI so I don't want to change the settings. I guess I could buy a new tv in the den that supports the higher resolution... lol.... someday soon...
bskuared is offline
Reply Digital Recorders (PVRs) General
