Help with cable hook -Up?(Digital box-HD TV-DVD Recorder) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-04-2008, 12:32 PM - Thread Starter
Trumpton's Avatar
Good afternoon,
I have just purchsed a Pioneer 160 GB Hard Drive/DVD recorder and I wish to hook this up to my current HD cable box (Rogers Cable) and Sony 42" HDTV. I thought this was going to be quite easy in concept, but after trying for an hour or so I am stuck.
Before I tried to hook up the recorder and I had the cable box feeding the TV (a DVI connection to a HDMI connection). My TV only has this one HDMI connection.
Is it possible to hook up the three componets only using the HDMI/DVI connections?
Thanks in advance for any assistance/advice,
Trumpton
Trumpton is offline
post #2 of 3 Old 02-04-2008, 02:39 PM
Super Moderator
markrubin's Avatar
Quoted: 1036 Post(s)
Liked: 2273
moved here for you: hope a member can help (you could also try HDTV recorders forum)
Welcome to AVS
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #3 of 3 Old 11-04-2008, 12:01 PM
velocci's Avatar
Quoted: 117 Post(s)
hi, are you still having problems with this? i'm thinking of getting an LCD TV and have it co-exist with my non-HD Pioneer recorder, i think its model DVR543HS. you may have the same model as me exept yours has the 160gb HDD and mine has the 80gb hardrive. please see my post on this and let me know if you can answer any of the questions. thanks.
http://www.avsforum.com/avs-vb/showt...4#post15004394
Originally Posted by Trumpton View Post
Good afternoon,
Trumpton
www.johnvelocci.com
system: Onkyo TX-NR 646 AVR with Polk Audio RtiA3 fronts and
BIC America F12 sub
velocci is offline
Reply Digital Recorders (PVRs) General
