Transferring from DirecTV DVR hard-drive to PCs hard-drive - AVS Forum
post #1 of 2 Old 02-08-2008, 06:27 AM - Thread Starter
Hangrumps's Avatar
DirecTV has two DVRs that have an Ethernet port. HR21-200 and HR21-700. Is there a way to transfer or stream from DirecTV DVR hard-drive to your PCs hard-drive using the ethernet connection. Replay TV with the help of a program called DVArchive allows you to transfer from Replay TV to your PC. Replay TV was just bought by DirecTV. Does anyone know a way to transfer from a DirecTV DVR to your PC?
Hangrumps is offline
post #2 of 2 Old 02-08-2008, 07:22 AM
bfdtv's Avatar
DirecTV is expected to sell a special tuner box for Windows Vista in the next year. That will allow you to use Windows Vista Media Center to do your recording, although it may require a new OEM Vista PC.
But there is no way to transfer recordings from the DirecTV HR20/HR21 DVR to your computer. You should not expect to ever see that capability.
For the foreseeable future, high-definition download from the DVR to PC via ethernet is a "TiVo exclusive" feature.
bfdtv is offline
Reply Digital Recorders (PVRs) General
User Tag List
