Bright House Problems with External Hard Drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-12-2008, 04:18 PM - Thread Starter
xsidearmx's Avatar
I seem to be having issues that are unique. I attach my hard drive to the 8300HDC and it finds it fine and formats it. The DVR seem to work fine for awhile but then it locks up or reboots. I have tried 3 DVR's and 2 hard drives with no luck. Any one know what maybe going on? I have Bright House of Central Florida
xsidearmx is offline
post #2 of 6 Old 02-12-2008, 09:25 PM
bfdtv's Avatar
Did you use a hard drive recommended in the SA8300 thread in the HDTV Recorders forum?
Many external hard drives do not work reliably with the SA8300.
bfdtv is offline
post #3 of 6 Old 02-13-2008, 10:19 AM - Thread Starter
xsidearmx's Avatar
Yes have tried 2 of them from different vendors.
post #4 of 6 Old 02-13-2008, 11:02 AM
bfdtv's Avatar
That doesn't answer the question.
Many external drives -- from different vendors -- will not work reliably. Make sure you see the SA8300HD external drive thread and use what they recommend.
bfdtv is offline
post #5 of 6 Old 02-13-2008, 04:38 PM - Thread Starter
xsidearmx's Avatar
I am using the Apricorn dvr Xpander which is stated to be compatible. I also tried Western Digital my expander (which I can not find) and it did not work either.
post #6 of 6 Old 08-21-2010, 12:15 AM
robha19's Avatar
Hi. I've attached a Hitachi 1tb external hard drive to a Scientific Atlanta 8300HDC. It
loads and formats and records. But during playback, it pixelates for about a half second every minute or so. I've tried three different external drives and now today have tried
a second 8300HDC. What's going on here? What do I need to do to get stable
recordings/playbacks?
robha19 is offline
Reply Digital Recorders (PVRs) General
