Sirius Receiver replacment - why are new receivers 5V!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-21-2009, 04:50 PM - Thread Starter
metropole's Avatar
Quoted: 44 Post(s)
My trusty http://www.audiovox.com/manuals/owners/128-6901.pdf seems to have died.
I looked at some online sites for replacement receivers and specials. I was wondering if someone could suggest a replacement where I don't need to purchase everything and that fits with my current installation in my car.
I have the SIRPNP2 custom installed in the car with a dock that is screwed to a metal bracket which goes behind the dash. I was hoping to find a receiver and possibly dock that I can screw on in place of the old one. As well as using all the cable connectors from the car kit: http://www.tss-radio.com/audiovox-pn...k1-p-4460.html
So, with other words I'm hoping to reuse all plugs that go into the dock of the receiver and find a dock that is compatible with my current bracket.
· Power
-> I'm gathering that I could have an issue as newer units use 5V. Are there any docks that have a 12V to 5 V adapter integrated?
· Antenna
· FM adapter (mini pin to FM)
Since it is an older car I didn't want to get to crazy with the replacement.
metropole is offline
post #2 of 3 Old 08-25-2009, 09:39 AM
ClubSteeler's Avatar
Savr yourself the headache and just replace the receiver..
http://cgi.ebay.com/Sirius-Audiovox-...d=p3286.c0.m14
ClubSteeler is offline
post #3 of 3 Old 09-07-2009, 11:09 AM
Rammitinski's Avatar
Ah, so.
Rammitinski is offline
Reply XM and Sirius Satellite Radio
